12-02-2020 05:18 PM
When I reconfigure the VADJ rail from default 2.5V to 1.8V, Vivado hardware manager is unable to connect to the board and the on-board fan covering the Zynq SoC stops running when I power on the board.
In the user manual page 82, it says the following:
"In this mode the user can control when to turn on VADJ and to which voltage level (1.8V, 2.5V , 3.3V)." This implies that it can be set to 1.8V, yet it causes the problems I mentioned above.
What is the correct process in reconfiguring VADJ from the default 2.5V to another voltage?
12-09-2020 01:49 AM
Hello @evelynschao ,
See this similar post that may help you with your issue:
Hope this helps.
