Observer gianmarcoborri
ZC706 GTX SerDes
Hello all,
I have a ZC706 board (Zynq-7000 FPGA) and I'd like using Si5324 to generate a reference clock for a Quad 110 SerDes .
[UG954 p. 40]
Quad 110:
° MGTREFCLK0 - FMC_HPC_GBTCLK1_M2C clock
° MGTREFCLK1 - SI5324_OUT_C_P/N jitter attenuator clock
° Contains 4 GTX transceivers allocated to FMC_HPC_DP[7:4]_C2M_P/N
In this block RXP/N and TXP/N pads are all connect to the FMC HPC and in my design I can'use other boards, so this SerDes Channel is not available...
...I forgot this and I constrained and connect RXP/N and TXP/N ports to ZC706 SMA, but it seems they belong to another SerDes Quad
Quad 111
° MGTREFCLK0 - FMC_LPC_GBTCLK0_M2C_C_P/N
° MGTREFCLK1 - SMA_MGT_REFCLK_P/N SMA GTX clock input
° Contains 1 GTX transceiver allocated to FMC_LPC_DP0_C2M_P/N
° Contains 1 GTX transceiver allocated to SMA_MGT_TX_P/N and RX_P/N SMA
connectors
° Contains 1 GTX transceiver allocated to SFP_TX and _RX_P/N SFP/SFP+ connector
Surprisingly, my system works perfectly but it seems very strange. Is it possible that working SerDes belongs to Quad 111 instead Quad 110? I checked that in Quad111 there are no activated reference clocking sources.
Anyone can help me to understand it?
Thanks in advice
Gianmarco Borri
回复: ZC706 GTX SerDes
Hi gianmarcoborri,
In the GTX structure, the Quad 111 can use the clock from Quad 110 as reference clock, but it need to make some settings in the design. The details can be found in the UG476,  Ch2 Reference Clock Selection and Distribution -->Reference Clock Selection and Distribution.
So you can double check if your design has selected the MGTREFCLK1 of Quad 111 as Quad110 ref clock.
Hi gianmarcoborri,
ZC706 GTX SerDes
Hi zhiq,
thanks for this marvelous reply. You're right, I didn't read this in the GTX reference clock interconnection
Thanks again
Gianmarco Borri
Participant nishantseth07
Re: ZC706 GTX SerDes
HI Gianmarco Borri
I want to transmit my serial data using SMA GTX of zc706 board. I have gone through the link to use GTX port "https://www.xilinx.com/support/documentation/boards_and_kits/zc706/2014_4/xtp243-zc706-ibert-c-2014-4.pdf" But i am not able to find a solution where should i change the code to send my custom data.
You are using the same platform for GTX. Please help me if you have any idea to transmit new custom data using SMA GTX.
