jwoeber
ZCU102 openamp precompiled (Quick Try) petaLinux example kernel panic
I tried running the Quick Try example for OpenAMP as desccribed in UG1186 (v2018.2) June 6, 2018 page 27 which resulted in a kernel Panic. I was using the files from the ZCU102 ZU9 ES2 Rev 1.0 BSP (tried the ZCU102 BSP (prod-silicon) as well, same result) 2018.2 example project. Am I missing something obvious?
MfG
Johannes
U-Boot 2018.01 (Jun 15 2018 - 04:10:27 -0600) Xilinx ZynqMP ZCU102 rev1.0
I2C:   ready
DRAM:  4 GiB
EL Level:	EL2
Chip ID:	zu9eg
MMC:   sdhci@ff170000: 0 (SD)
SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 MAC addresses don't match:
Address in ROM is          ff:ff:ff:ff:ff:ff
Address in environment is  00:0a:35:00:22:01
eth0: ethernet@ff0e0000
ZynqMP>  mmcinfo && fatload mmc 0 ${netstart} ${kernel_img} &&  fatload mmc 0 0x14000000 openamp.dtb
Device: sdhci@ff170000
Manufacturer ID: 5d
OEM: 5342
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
48826144 bytes read in 3221 ms (14.5 MiB/s)
reading openamp.dtb
38296 bytes read in 20 ms (1.8 MiB/s)
ZynqMP>  bootm $netstart - $netstart 0x14000000
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000108
     Data Size:    6960376 Bytes = 6.6 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   90597ecd23b0a2188f8dc7310e4740976addec3d
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x106a3704
     Data Size:    41456 Bytes = 40.5 KiB
     Hash algo:    sha1
     Hash value:   c3228e02a058f810e26343561d0b9dc3a3a86a9e
   Booting using the fdt blob at 0x106a3704
   Uncompressing Kernel Image ... OK
   Loading Device Tree to 0000000007ff2000, end 0000000007fff1ef ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0-xilinx-v2018.2 (oe-user@oe-host) (gcc version 7.2.0 (GCC)) #1 SMP Fri Jun 15 04:13:44 MDT 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 1024 MiB at 0x000000003fc00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] random: fast init done
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff65000 s46488 r8192 d31336 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1033987
[    0.000000] Kernel command line: earlycon clk_ignore_unused earlyprintk root=/dev/mmcblk0p2 rw rootwait cma=1024M
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0x3bc00000-0x3fc00000] (64MB) mapped at [ffffffc03bc00000-ffffffc03fbfffff]
[    0.000000] Memory: 2998040K/4193280K available (9980K kernel code, 644K rwdata, 3128K rodata, 512K init, 2168K bss, 146664K reserved, 1048576K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a40000   (  9984 KB)
[    0.000000]     .rodata : 0xffffff8008a40000 - 0xffffff8008d60000   (  3200 KB)
[    0.000000]       .init : 0xffffff8008d60000 - 0xffffff8008de0000   (   512 KB)
[    0.000000]       .data : 0xffffff8008de0000 - 0xffffff8008e81200   (   645 KB)
[    0.000000]        .bss : 0xffffff8008e81200 - 0xffffff800909f2b0   (  2169 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU event tracing is enabled.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8dc196, max_idle_ns: 440795203664 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511099ns
[    0.008303] Console: colour dummy device 80x25
[    0.012559] console [tty0] enabled
[    0.015926] bootconsole [cdns0] disabled
[    0.019836] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[    0.019850] pid_max: default: 32768 minimum: 301
[    0.019951] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.019969] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.020524] ASID allocator initialised with 65536 entries
[    0.020572] Hierarchical SRCU implementation.
[    0.020904] EFI services will not be available.
[    0.020928] zynqmp_plat_init Platform Management API v1.0
[    0.020937] zynqmp_plat_init Trustzone version v1.0
[    0.021033] smp: Bringing up secondary CPUs ...
[    0.021283] Detected VIPT I-cache on CPU1
[    0.021311] CPU1: Booted secondary processor [410fd034]
[    0.021584] Detected VIPT I-cache on CPU2
[    0.021602] CPU2: Booted secondary processor [410fd034]
[    0.021863] Detected VIPT I-cache on CPU3
[    0.021881] CPU3: Booted secondary processor [410fd034]
[    0.021922] smp: Brought up 1 node, 4 CPUs
[    0.021955] SMP: Total of 4 processors activated.
[    0.021964] CPU features: detected feature: 32-bit EL0 Support
[    0.021974] CPU: All CPU(s) started at EL2
[    0.021991] alternatives: patching kernel code
[    0.022710] devtmpfs: initialized
[    0.027316] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.027339] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.048351] xor: measuring software checksum speed
[    0.087966]    8regs     :  2302.000 MB/sec
[    0.127996]    8regs_prefetch:  2052.000 MB/sec
[    0.168027]    32regs    :  2830.000 MB/sec
[    0.208058]    32regs_prefetch:  2381.000 MB/sec
[    0.208066] xor: using function: 32regs (2830.000 MB/sec)
[    0.208136] pinctrl core: initialized pinctrl subsystem
[    0.208629] NET: Registered protocol family 16
[    0.209440] cpuidle: using governor menu
[    0.209997] vdso: 2 pages (1 code @ ffffff8008a46000, 1 data @ ffffff8008de4000)
[    0.210014] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.210466] DMA: preallocated 256 KiB pool for atomic allocations
[    0.239945] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.240505] ARM CCI_400_r1 PMU driver probed
[    0.245305] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.253161] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.320319] raid6: int64x1  gen()   403 MB/s
[    0.388264] raid6: int64x1  xor()   445 MB/s
[    0.456357] raid6: int64x2  gen()   688 MB/s
[    0.524363] raid6: int64x2  xor()   603 MB/s
[    0.592400] raid6: int64x4  gen()  1042 MB/s
[    0.660453] raid6: int64x4  xor()   742 MB/s
[    0.728522] raid6: int64x8  gen()   980 MB/s
[    0.796530] raid6: int64x8  xor()   745 MB/s
[    0.864623] raid6: neonx1   gen()   726 MB/s
[    0.932607] raid6: neonx1   xor()   852 MB/s
[    1.000659] raid6: neonx2   gen()  1168 MB/s
[    1.068719] raid6: neonx2   xor()  1207 MB/s
[    1.136784] raid6: neonx4   gen()  1506 MB/s
[    1.204820] raid6: neonx4   xor()  1441 MB/s
[    1.272871] raid6: neonx8   gen()  1652 MB/s
[    1.340905] raid6: neonx8   xor()  1533 MB/s
[    1.340913] raid6: using algorithm neonx8 gen() 1652 MB/s
[    1.340920] raid6: .... xor() 1533 MB/s, rmw enabled
[    1.340928] raid6: using neon recovery algorithm
[    1.342304] SCSI subsystem initialized
[    1.342453] usbcore: registered new interface driver usbfs
[    1.342490] usbcore: registered new interface driver hub
[    1.342526] usbcore: registered new device driver usb
[    1.342586] media: Linux media interface: v0.10
[    1.342613] Linux video capture interface: v2.00
[    1.342659] pps_core: LinuxPPS API ver. 1 registered
[    1.342668] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.342689] PTP clock support registered
[    1.342718] EDAC MC: Ver: 3.0.0
[    1.343041] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.343185] FPGA manager framework
[    1.343288] fpga-region fpga-full: FPGA Region probed
[    1.343377] Advanced Linux Sound Architecture Driver Initialized.
[    1.343627] Bluetooth: Core ver 2.22
[    1.343659] NET: Registered protocol family 31
[    1.343667] Bluetooth: HCI device and connection manager initialized
[    1.343680] Bluetooth: HCI socket layer initialized
[    1.343689] Bluetooth: L2CAP socket layer initialized
[    1.343707] Bluetooth: SCO socket layer initialized
[    1.344236] clocksource: Switched to clocksource arch_sys_counter
[    1.344308] VFS: Disk quotas dquot_6.6.0
[    1.344352] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.349104] NET: Registered protocol family 2
[    1.349389] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.349599] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.349982] TCP: Hash tables configured (established 32768 bind 32768)
[    1.350055] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.350132] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.350280] NET: Registered protocol family 1
[    1.350482] RPC: Registered named UNIX socket transport module.
[    1.350492] RPC: Registered udp transport module.
[    1.350499] RPC: Registered tcp transport module.
[    1.350506] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.350950] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.351094] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.351699] audit: initializing netlink subsys (disabled)
[    1.352358] audit: type=2000 audit(1.332:1): state=initialized audit_enabled=0 res=1
[    1.352842] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    1.353554] NFS: Registering the id_resolver key type
[    1.353573] Key type id_resolver registered
[    1.353581] Key type id_legacy registered
[    1.353593] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.353614] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.377252] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.377268] io scheduler noop registered
[    1.377276] io scheduler deadline registered
[    1.377296] io scheduler cfq registered (default)
[    1.377304] io scheduler mq-deadline registered
[    1.377312] io scheduler kyber registered
[    1.377925] nwl-pcie fd0e0000.pcie: Link is DOWN
[    1.377968] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges:
[    1.377989] OF: PCI:   MEM 0xe0000000..0xefffffff -> 0xe0000000
[    1.378002] OF: PCI:   MEM 0x600000000..0x7ffffffff -> 0x600000000
[    1.378127] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[    1.378141] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.378151] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[    1.378163] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[    1.378416] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[    1.379183] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.379552] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.379709] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.379864] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.380018] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.380173] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.380349] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.380518] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.380689] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.380921] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.381076] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.381229] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.381379] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.381532] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.381688] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.381843] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.381993] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.406508] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.409460] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.413516] brd: module loaded
[    1.416772] loop: module loaded
[    1.417584] ahci-ceva fd0c0000.ahci: couldn't get PHY in node ahci: -517
[    1.417737] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.418746] m25p80 spi0.0: n25q512a (131072 Kbytes)
[    1.418769] 4 ofpart partitions found on MTD device spi0.0
[    1.418777] Creating 4 MTD partitions on "spi0.0":
[    1.418788] 0x000000000000-0x000001e00000 : "boot"
[    1.419187] 0x000001e00000-0x000001e40000 : "bootenv"
[    1.419555] 0x000001e40000-0x000004240000 : "kernel"
[    1.419930] 0x000004240000-0x000008000000 : "spare"
[    1.421175] libphy: Fixed MDIO Bus: probed
[    1.422203] tun: Universal TUN/TAP device driver, 1.6
[    1.422339] CAN device driver interface
[    1.424322] macb ff0e0000.ethernet: Not enabling partial store and forward
[    1.424700] libphy: MACB_mii_bus: probed
[    1.426317] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 31 (00:0a:35:00:22:01)
[    1.426333] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[    1.426842] usbcore: registered new interface driver asix
[    1.426895] usbcore: registered new interface driver ax88179_178a
[    1.426926] usbcore: registered new interface driver cdc_ether
[    1.426956] usbcore: registered new interface driver net1080
[    1.426986] usbcore: registered new interface driver cdc_subset
[    1.427018] usbcore: registered new interface driver zaurus
[    1.427059] usbcore: registered new interface driver cdc_ncm
[    1.427325] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    1.428390] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.428401] ehci-pci: EHCI PCI platform driver
[    1.428658] usbcore: registered new interface driver uas
[    1.428696] usbcore: registered new interface driver usb-storage
[    1.429169] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    1.429220] i2c /dev entries driver
[    1.430204] IR NEC protocol handler initialized
[    1.430213] IR RC5(x/sz) protocol handler initialized
[    1.430221] IR RC6 protocol handler initialized
[    1.430228] IR JVC protocol handler initialized
[    1.430235] IR Sony protocol handler initialized
[    1.430242] IR SANYO protocol handler initialized
[    1.430249] IR Sharp protocol handler initialized
[    1.430256] IR MCE Keyboard/mouse protocol handler initialized
[    1.430264] IR XMP protocol handler initialized
[    1.431225] usbcore: registered new interface driver uvcvideo
[    1.431234] USB Video Class driver (1.1.1)
[    1.431776] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff800913d000 with timeout 10s
[    1.431945] Bluetooth: HCI UART driver ver 2.3
[    1.431955] Bluetooth: HCI UART protocol H4 registered
[    1.431963] Bluetooth: HCI UART protocol BCSP registered
[    1.431991] Bluetooth: HCI UART protocol LL registered
[    1.431999] Bluetooth: HCI UART protocol ATH3K registered
[    1.432007] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.432049] Bluetooth: HCI UART protocol Intel registered
[    1.432058] Bluetooth: HCI UART protocol QCA registered
[    1.432096] usbcore: registered new interface driver bcm203x
[    1.432129] usbcore: registered new interface driver bpa10x
[    1.432162] usbcore: registered new interface driver bfusb
[    1.432199] usbcore: registered new interface driver btusb
[    1.432208] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    1.432303] usbcore: registered new interface driver ath3k
[    1.432432] EDAC MC: ECC not enabled
[    1.432589] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    1.433085] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880 KHz
[    1.433140] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    1.433504] sdhci: Secure Digital Host Controller Interface driver
[    1.433513] sdhci: Copyright(c) Pierre Ossman
[    1.433520] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.480283] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    1.486295] ledtrig-cpu: registered to indicate activity on CPUs
[    1.486435] usbcore: registered new interface driver usbhid
[    1.486444] usbhid: USB HID core driver
[    1.488221] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    1.489993] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    1.492218] Netfilter messages via NETLINK v0.30.
[    1.492343] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.492483] Initializing XFRM netlink socket
[    1.492541] NET: Registered protocol family 10
[    1.492941] Segment Routing with IPv6
[    1.492985] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.493167] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.493467] NET: Registered protocol family 17
[    1.493483] NET: Registered protocol family 15
[    1.493501] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.493518] Ebtables v2.0 registered
[    1.493607] can: controller area network core (rev 20170425 abi 9)
[    1.493640] NET: Registered protocol family 29
[    1.493655] can: raw protocol (rev 20170425)
[    1.493663] can: broadcast manager protocol (rev 20170425 t)
[    1.493674] can: netlink gateway (rev 20170425) max_hops=1
[    1.493870] Bluetooth: RFCOMM TTY layer initialized
[    1.493883] Bluetooth: RFCOMM socket layer initialized
[    1.493898] Bluetooth: RFCOMM ver 1.11
[    1.493909] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.493919] Bluetooth: BNEP filters: protocol multicast
[    1.493930] Bluetooth: BNEP socket layer initialized
[    1.493938] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.493948] Bluetooth: HIDP socket layer initialized
[    1.494060] 9pnet: Installing 9P2000 support
[    1.494079] Key type dns_resolver registered
[    1.494482] registered taskstats version 1
[    1.494799] Btrfs loaded, crc32c=crc32c-generic
[    1.501039] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 47, base_baud = 6249375) is a xuartps
[    1.879692] mmc0: new high speed SDHC card at address 0001
[    1.883966] mmcblk0: mmc0:0001 0032G 29.7 GiB
[    1.889379]  mmcblk0: p1 p2 p3 p4
[    3.139014] console [ttyPS0] enabled
[    3.143171] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 48, base_baud = 6249375) is a xuartps
[    3.153729] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[    3.161943] PLL: shutdown
[    3.164624] PLL: shutdown
[    3.167524] PLL: enable
[    3.170017] PLL: shutdown
[    3.173379] PLL: enable
[    3.175840] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    3.186428] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    3.194381] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    3.202584] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.214943] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.227566] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[    3.237666] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[    3.244580] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.251115] [drm] No driver support for vblank timestamp query.
[    3.257071] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008af7228)
[    4.344249] [drm] Cannot find any crtc or sizes
[    4.348859] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[    4.356886] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[    4.365828] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[    4.383693] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    4.392581] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    4.402842] scsi host0: ahci-ceva
[    4.406263] scsi host1: ahci-ceva
[    4.409597] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 45
[    4.417435] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 45
[    4.427030] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[    4.437026] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.442446] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.450293] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
[    4.458941] xhci-hcd xhci-hcd.0.auto: irq 53, io mem 0xfe200000
[    4.464924] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.471640] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.478842] usb usb1: Product: xHCI Host Controller
[    4.483703] usb usb1: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[    4.490386] usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.495517] hub 1-0:1.0: USB hub found
[    4.499209] hub 1-0:1.0: 1 port detected
[    4.503270] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.508685] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.516362] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.524469] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.531180] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.538383] usb usb2: Product: xHCI Host Controller
[    4.543242] usb usb2: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[    4.549927] usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.555019] hub 2-0:1.0: USB hub found
[    4.558706] hub 2-0:1.0: 1 port detected
[    4.563661] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[    4.573869] pca953x 0-0020: interrupt support not compiled in
[    4.579631] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator
[    4.589502] pca953x 0-0021: interrupt support not compiled in
[    4.595941] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.602637] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.609330] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.616016] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.622712] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.629405] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.636097] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.642789] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.649489] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.656190] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.662499] i2c i2c-0: Added multiplexed i2c bus 3
[    4.667849] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[    4.674545] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.681239] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.687933] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.694620] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.701317] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.708007] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.714705] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.721007] i2c i2c-0: Added multiplexed i2c bus 4
[    4.738433] ata1: SATA link down (SStatus 0 SControl 330)
[    4.743780] ata2: SATA link down (SStatus 0 SControl 330)
[    4.772047] i2c i2c-0: Added multiplexed i2c bus 5
[    4.776887] i2c i2c-0: Added multiplexed i2c bus 6
[    4.781597] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[    4.788910] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 33
[    4.796440] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    4.803091] i2c i2c-1: Added multiplexed i2c bus 7
[    4.808018] i2c i2c-1: Added multiplexed i2c bus 8
[    4.814748] si570 9-005d: registered, current frequency 300000000 Hz
[    4.821055] i2c i2c-1: Added multiplexed i2c bus 9
[    4.839726] si570 10-005d: registered, current frequency 148500000 Hz
[    4.846123] i2c i2c-1: Added multiplexed i2c bus 10
[    4.851135] i2c i2c-1: Added multiplexed i2c bus 11
[    4.856048] i2c i2c-1: Added multiplexed i2c bus 12
[    4.860959] i2c i2c-1: Added multiplexed i2c bus 13
[    4.865873] i2c i2c-1: Added multiplexed i2c bus 14
[    4.870671] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[    4.878542] i2c i2c-1: Added multiplexed i2c bus 15
[    4.883471] i2c i2c-1: Added multiplexed i2c bus 16
[    4.888389] i2c i2c-1: Added multiplexed i2c bus 17
[    4.893606] i2c i2c-1: Added multiplexed i2c bus 18
[    4.898526] i2c i2c-1: Added multiplexed i2c bus 19
[    4.903454] i2c i2c-1: Added multiplexed i2c bus 20
[    4.908372] i2c i2c-1: Added multiplexed i2c bus 21
[    4.913294] i2c i2c-1: Added multiplexed i2c bus 22
[    4.918094] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[    4.925667] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 34
[    4.932728] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.939531] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-09-05 10:42:04 UTC (1567680124)
[    4.948445] clk: Not disabling unused clocks
[    4.952669] ALSA device list:
[    4.955577]   #0: DisplayPort monitor
[    4.960524] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    4.971906] EXT4-fs (mmcblk0p2): recovery complete
[    4.976627] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.984706] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    4.991236] devtmpfs: error mounting -2
[    4.995106] Freeing unused kernel memory: 512K
[    4.999567] Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[    5.013659] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.14.0-xilinx-v2018.2 #1
[    5.020856] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[    5.025803] Call trace:
[    5.028240] [<ffffff8008088c58>] dump_backtrace+0x0/0x368
[    5.033619] [<ffffff8008088fd4>] show_stack+0x14/0x20
[    5.038653] [<ffffff8008a13b78>] dump_stack+0x9c/0xbc
[    5.043688] [<ffffff800809bdc0>] panic+0x11c/0x274
[    5.048462] [<ffffff8008a25fbc>] kernel_init+0xec/0x100
[    5.053670] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    5.058965] SMP: stopping secondary CPUs
[    5.062920] Kernel Offset: disabled
[    5.066342] CPU features: 0x002004
[    5.069726] Memory Limit: none
[    5.072769] ---[ end Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
dragosht
I was only able to get it working after I changed project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi to include the openamp/rpmsg/ipi-mailbox device-tree nodes and rebuilt petalinux. Using the system-user.txt file from this post here: https://forums.xilinx.com/t5/OpenAMP/rpmsg-device-is-not-created-in-sys-bus-rpmsg-devices-ZynqMP/td-p/1002106 worked from me.
I think the problem comes from using that FIT image.ub file which already contains a dtb file inside (and it loads that anyway). Loading that openamp.dtb with fatload is probably messing something up there ...
dragosht
For what it's worth - I'm experiencing the exact same error when trying out the OpenAMP buit-in files from 2019.01 ...
gkuhn
I have the same issue as well.
dragosht
gkuhn
Thanks very much. Indeed, when I build the OS image myself with a version of the dtsi with openamp.dtsi included, it works. I guess the issue here is simply that the quick-start procedure as documented simply doesn't work.
If I may be so bold as to hijack this thread, when I run the example apps, such as the matrix multiplication one, I can see the UART output from the A53, obviously as part of an interactive session but I see no output at all stemming from the R5. This is the case both for the bundled R5 application as well as when I build the example R5 code manually using xilinx SDK.  (I'm using 2019.1). I can see no configuration problems on the R5,  stdin+stdout is set to UART0 and I would have thought that the outputs of both cores would be visible on the terminal.
Do you have any insight as to why I am not seeing the R5's output?
dragosht
I can confirm that I see no R5 console logs in the echo_test and mat_mul_demo demos as well, but I haven't spent much time debugging those. For the image_rpc_demo it seems to work in both standalone and FreeRTOS versions ...
gkuhn
Thanks for taking the time to confirm that. That's useful because at least I know that it's probably not something I have inadvertently have set incorrectly on the A53 side. Cheers.
