ZCU102 with ES2 Silicon built with Vivado and petalinux 2019.1
Booting an old board up again.  Am I out of luck to try this combo?  I do not see support for MPSOC ES devices in the installation.  Do you suggest building with 2018.3 then moving the project into 2019?
Re: ZCU102 with ES2 Silicon built with Vivado and petalinux 2019.1
Hello @coreyhahn
We don't recommend to work with non matching version of tools. That will be problematic for you, beceause you will not be able to match driver repository version to the IP version.
If you look closely, the support for Xilinx BSP is also until 2018.3 only for ZCU102.
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools/2018-3.html
So unfortunately you will need to work on 2018.3. But this is something will not be frutiful for your product development cycle.
upgrading Production ZCU102 will be more viable.
Thank you.
Hello @coreyhahn
Thank you.
