vignesh_econ
ZCU104 HDMI OUT
In ZCU104 eval board, there is two HDMI connector. which connected through SN65DP159RGZ and TMDS181IRGZT. Can we use both as HDMI out (which is HDMI TX) ? Is there any possibility to configure both as HDMI TX?
Please advice..!!
Vignesh
kvasantr
Hello @vignesh_econ,
Please refer page number 58 of UG1267.
as per the direction of clocking we cannot use both ports or cannot be configured as HDMI TX.
Thank you
kvasantr
Thank you
el3ctrician
am sorry for the stupid question but i am a bit confused, are both of the port mapped to dedicated pin so that both of them can be used at the same time ?
