jcrash29
ZCU106 PCIe Driver
Hi Everyone,
I am attempting to setup a PCIe design on the ZCU106 board. The goal is to send large amounts of data between the FPGA and a linux Ubuntu system.
I noticed there are two different Functional Modes for the PCIe IP block: DMA, and AXI Bridge.
What is the difference between DMA and AXI Bridge?
I found the linux driver for the PCI-DMA(65444).
Is there a similar driver for the AXI Bridge mode?
EDIT: I found the following driver: here that appears to be for AXI Bridge, but this driver appears to be for if the linux system is running on the SOC
