ZCU106 template (hollow shell) project
I just received a ZCU106 board and I'm looking for a top level (like a hollow shell, if possible in VHDL) with pins defined and xdc but I don't found it. It looks basic for me but I did'nt found it. Did I missed something ?
Thank you.
Re: ZCU106 template (hollow shell) project
Hi @facotl ,
I could not understand, what do you mean with "hollow shell".
Which kind of design you are planning, you can find it in Xilinx application Notes. (That is best practices)
One of Example design for your board is here.
Hello @facotl ,
Is there any further assistance required in relation to this matter? If so, please let us know and we will be glad to help you further then.
If not, and if @sabankocal suggestion helped you to answer your query, please mark a response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then? We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
