ZCU111 ADC IO
The XM500 companion board for the ZCU111 (pictured on p95 of UG1271) has a pair of 2x10 headers each of which supports 20 signals referred to as "ADC I/Os" and "DAC I/Os". It seems they connect directly to the chip (p100). Are they just regular I/O signals, or is there some special significance attached to their designation as ADC or DAC I/Os?
Re: ZCU111 ADC IO
Hi @drb13
This is already discussed here
https://forums.xilinx.com/t5/Versal-and-UltraScale/RFSoC-What-ar-DACIO-and-ADCIO-ports-used-for/td-p/966100
Please refer the response of @klumsde
Re: ZCU111 ADC IO
Hi @drb13
