Observer takagiwa_mish
ZCU111 and XM500 differential analog input and GUI
Could anybody tell me analog signal level for differential input on XM500 and ZCU111?
I believe these SMA ports were connected to ZU+ device directly.
DS926 (v1.5) Table 114 said Common mode voltage is 1.25V and Full-scale Input is 1Vpp.
PG269 (v2.1) Figure 8 and Figure 10 said VCM = 1.2V and Normal range is +/-0.25V.
UG1309 (v1.1) said "Connecting differential ports is also acceptable, however, a DC blocker is required on both the P and N connectors." on Loopback Test Example = I thought it said there are no common mode voltage. I could see common mode voltage on D/A differential output.
I tried these three kind of signal using non-MTS design and RF Data Converter Evaluation Tool.
But I got noise on all three signals (on GUI).
Best regards,
Re: ZCU111 and XM500 differential analog input and GUI
Hi takagiwa,
The XM500 connects to the FMC connector on the ZCU111.
The schematics for both are available here:
https://www.xilinx.com/products/boards-and-kits/zcu111.html#documentation
Let us know if you have questions.
Andres
Hello Andres,
Thank you for your respeonse.
I believe I don't need to mind about XM500 when I think about static characteristics of differential analog I/O.
Now I'm confusing about signal level of ZU+ device because I found three different description.
Best regards,
Takagiwa
