ZCU111 board LMX clock programming
I am trrying to set up a simple block design with rfdc. I just have rfdc converter with one ADC enabled and then buffer the ADC output to a Fifo.
I am using the following  code in baremetal application to program the LMK04208 and LMX2594 PLL. The application can launched successfully, but it does not generate the clock signal and there is no data ouput from the ADC( I have attache an ILA at the output data of rdfc, and it said no clock stop and not armed). Any idea of what could be wrong? Also, what is the exact meaning of the following code? Which tile clock has been connected? Is the clock generated by LMX2594 3932160 kHz?
#ifdef XPS_BOARD_ZCU111
printf("\n Configuring the Clock \r\n");
#ifdef __BAREMETAL__
LMK04208ClockConfig(1, LMK04208_CKin);
LMX2594ClockConfig(1, 3932160);
#else
LMK04208ClockConfig(12, LMK04208_CKin);
LMX2594ClockConfig(12, 3932160);
#endif
#endif
Hi @chaooxford
I see you have posted another thread about this issue with with the clock not being programmed.
https://forums.xilinx.com/t5/UltraScale-Architecture/RFSoC-simple-ADC-project-no-effective-clock-generated-by-LMX/td-p/957029
which version of the driver are you using.
there was an issue before where the loop that was used to pick the settings was not properly constructed.
Can you try the latest version of the xrfdc_clk.c andsee if it works.
Are the LEDs on the ZCU111 board coming on to indicate the PLLs are locked on the board?
Keith
Hi @klumsde
Thanks for your reply.
I am using the code from this link. Is it the latest? Which are the LEDs indicate PLL lock?
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/rfdc/examples/xrfdc_clk.c
I am using the following as main.
The COM5 do the following and stucked XRFdc_GetIPStatus. Any idea what is wrong with that?
LMK04208 configuration write done
LMX configured to frequency 5120000
I2c1 I2CTOSPI LMX2594 PLL configuration done
Configured the Clock
int main(void)
int Status;
u16 Tile;
u16 Block;
XRFdc *RFdcInstPtr = &RFdcInst;
XRFdc_Config *ConfigPtr;
XRFdc_BlockStatus BlockStatus;
XRFdc_IPStatus myIPStatus;
printf("RFdc Selftest Example Test\r\n");
* Run the RFdc Decoder Mode example, specify the Device ID that is
* generated in xparameters.h.
/* Initialize the RFdc driver. */
ConfigPtr = XRFdc_LookupConfig(RFDC_DEVICE_ID);
if (ConfigPtr == NULL) {
return XRFDC_FAILURE;
Status = XRFdc_CfgInitialize(RFdcInstPtr, ConfigPtr);
if (Status != XRFDC_SUCCESS) {
LMX2594ClockConfig(1, 5120000);
printf("\n Configured the Clock \r\n");
#else
LMX2594ClockConfig(12, 5120000);
printf("\n Configured the Clock bb \r\n");
#endif
#endif
Status = XRFdc_GetIPStatus(RFdcInstPtr, &myIPStatus);
printf("\n Get IP statue \r\n");
int powerup_status;
int tile_state;
powerup_status = myIPStatus.ADCTileStatus[0].PowerUpState;
tile_state = myIPStatus.ADCTileStatus[0].TileState;
printf("ADC PowerUp Status: %u\n", powerup_status);
printf("ADC Tile State: %u\n", tile_state);
int whole, thousandths; // will need these for the doubles not supported by xil_printf
/*print out the ADC status*/
Status = XRFdc_GetBlockStatus(RFdcInstPtr, XRFDC_ADC_TILE, 0, 0, &BlockStatus);
whole = BlockStatus.SamplingFreq;
thousandths = (BlockStatus.SamplingFreq - whole) * 1000;
printf("ADC Sampling Frequency: %d.%3d\n",whole,thousandths);
Tile = 0x0;
for (Block = 0; Block <4; Block++) {
if (XRFdc_IsADCBlockEnabled(RFdcInstPtr, Tile, Block)) {
printf("\n tile %d block %d is available \r\n", Tile, Block);
if (RFdcInstPtr->ADC4GSPS == XRFDC_ADC_4GSPS) {
if ((Block == 2) || (Block == 3))
continue;
else if (Block == 1) {
if (XRFdc_IsADCBlockEnabled(RFdcInstPtr, Tile, 2) == 0)
continue;
xil_printf("Successfully ran Selftest Example Test\r\n");
return XRFDC_SUCCESS;
the code there is not correct. line 554 of xrfdc_clk.c shows the loop that is used to select the frequency.
for(XFreqIndex=0 ; XFreqIndex<20; XFreqIndex++) {
if (ClockingLmx[XFreqIndex].XFrequency == XFrequency) {
Lmx2594Updatei2c( XIicDevFile, ClockingLmx[XFreqIndex].LMX2594_A);
return 0;
The problem is the loop only goes to 20.
you should change the loop so it looks like
for(XFreqIndex=0 ; XFreqIndex < sizeof(ClockingLmx) / sizeof(ClockingLmx[0]); XFreqIndex++)
Keith
Hi @klumsde
Thanks for you reply.
Following the clock configuration, I had the code below.
int powerup_status;
int tile_state;
It print the as follows:
ADC PowerUp Status: 0
ADC Tile State: 7
Is it means the ADC is not powered up somehow.
Do i need to program the rfdc in the C code? Or anything else might be the cause?
Chao
it is stuck at clock detect I think
Hi @klumsde
I have make the change you suggested.
Is there anything else need to be configured?
Best,
Chao
Hi @klumsde
It still prints the same as before, which indicate the ADC is not powered up.
ADC Tile State: 7
Best,
Chao
As a sanity check can you program this frequency over the system controller? SCUI?
Hi @klumsde
I have found that I have used the wrong block number in the following code#
 Status = XRFdc_GetBlockStatus(RFdcInstPtr, XRFDC_ADC_TILE, 0, 1, &BlockStatus);
It not longer stucked it the code above and printed ADC Sampling Frequency: 4. 96 with code below.
But it still prints ADC PowerUp Status: 0 ADC Tile State: 7 for ADC tile check.
Is there any document about ADCTileStatus?
Best,
Chao
I have the same problem,
ADC Tile State: 7
ADC Sampling Frequency: 3.932
ADC00 Status AnalogDataPathStatus - 1
DigitalDataPathStatus - 801
DataPathClockStatus - 0
IsFIFOFlagsEnabled - 3
IsFIFOFlagsAsserted - 0
ADC Mixer Frequency: -499.-999
Has anyone found the solution to this problem? I tried to change the version of xrfdc_clk.c but it has no effect.
@chaooxford
Was having same issue.
If ADC tile status is 6 I believe that's indicating the LMK is not configured
If ADC tile status is 7 I believe that's indicating the LMX is not configured
I generated clock programming files from the TI TICS application and could configure the clocks using the SCUI example.  I don't believe I ever got the baremetal code to configure the clocks.
We're running linux now so I used the bootscript from here as a template:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/84541826/Programming+Clocks+on+the+ZCU111#ProgrammingClocksontheZCU111-Usingi2c-toolstoprogramtheLMKandLMXdevices:
Configuring the Si5382 was not necessary for me.
One missing detail from the bootscript.  Per the LMX2594 data sheet; after programming the registers, wait 10ms and program the R0 register one more time with the same value.  So, maybe this is also missing from the xfrdc_clk.c example?
Cheers
Thank you for your answer @aswejk .
I think I understand and you are right.
I removed the PLL enable to try to find another solution.
In fact, to configure it is necessary to program the converters once through the TICS Pro application, then the code under SDK works and allows to configure the frequency of the LMX2594 and the LMK04208. So the problem probably comes from the initialization of the registers because the 10 ms pause is correctly programmed with sleep(10). (see code screenshot). Is there a known and solved problem with this initialization of clock registers? @klumsde
Kind regards,
