Observer kikd180
ZCU111 how to send 4GHz bandwidth signal
Hello.
I'm trying to send 4GHz bandwidth signal from below settings , using RF Data Converter Evaluation User Interface.
  • Using DAC Tile ... DAC Tile1
  • PLL(Fs)                ... 5898.24MHz
  • Mixer Output    ... I/Q
  • Mixer Freq          ... 4000MHz
RFSoC send signal to 1.898GHz and 4GHz, but 1.898Ghz signal stronger than 4Ghz signal.
It seems mixer freq is folding from (5898.24/2)MHz.
Maybe, i'm misunderstanding to something about DAC settings.
Would you tell me to correct setting for send 4GHz bandwidth signal?
Regards.
Observer kikd180
Re: ZCU111 how to send 4GHz bandwidth signal
This issue is resolved myself.
When I posted this, Nyquist Zone was set Zone1.
I tried set Nyquist Zone is Zone 2 and attach 3000-4300 MHz band pass filter,
ZCU111 works as expected behavior.
Observer kikd180
