Participant 3008202060
ZYNQ APB AP transaction error
Hi ,
    I used Zedboard, and SDK is 2016.4.  If I just add arm core, axi_timer .. Everything works just fine. But after I tried to add something on the AXI.(packaged IP with AXI) It runs into problem : Memory write error at 0x100000. APB AP transaction error, DAP status f0000021.  I used run as-> launch on hardware (system debugger) to run the c project.
   The address 0x100000 is the address for DDR3, and I assigned my axi address to somewhere else. Has any idea? Thanks a lot.
Scholar jmcclusk
Re: ZYNQ APB AP transaction error
There's not enough information to diagnose the problem.   What does your system memory map look like?
   The address map looks like this. If I don't add the last one, it works fine.
