Anonymous
Not applicable
Zynq-7000 XC702 Board Dimensions
Hi, Has anyone got access to the board dimensions for the Xynq-7000 XC702. I have looked through all the downloadable files but it doesn't seem to be included. Would be grateful if someone could attached a DXF / PDF of this. Thanks Regards, Alan
Scholar pratham
Re: Zynq-7000 XC702 Board Dimensions
@Anonymous
https://secure.xilinx.com/webreg/register.do?group=clickthrough&cid=345710&cancellink=http%3A%2F%2Fwww.xilinx.com%2Fsupport%2Fdocumentation%2Findex.htm&eFrom=clicklicense_accept@xilinx.com&eSubject=Xilinx+Confidentiality+Agreement&eTo=clicklicense_accept@xilinx.com&emailFile=/scripts/clickLicense_Email.txt&group=clickthrough&htmlfile=/scripts/clickLicense.htm&license=RefDesLicense
-Pratham
Scholar pratham
Are you looking for board schematic of zc702?
-Pratham
The ZC702 board files can be found in the below link
http://www.xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html#documentation
By viewing the board files in Allegro Free viwer tool (http://www.cadence.com/products/pcb/pages/downloads.aspx) you can find board dimensions and other board parameters easily.
Hi,best way is to open board Allegro source files (available online) and extract dimensions from there.
Just for clarification, Xilinx recommends to use development boards in a stand-alone mode, i.e. not inserted or placed in a bigger system/environment where the conditions might led the board not to work properly in accordance with its specs.
a
Anonymous
Not applicable
Hi, Thanks for the link, looking on that link there is listed: AMS Allegro Board PDF (Rev 1.0) ( ver1.0, 245 KB ) [ZIP] ams-allegro-board-source-rdf0267-rev1-0.zip ams-gerber-files-rdf0269-rev1-0.zip But these don't seem to be of the development board XC702, am I missing something?
Anonymous
Not applicable
Hi, I have downloaded "Allegro/SIP/MCM FREE Physical Viewers 16.6 - 17MB" but this is not compatible with the .brd allegro file listed. The PDF does not look like the XC702 development PCB. Could someone attached either a compatible .brd file for 15.7 allegro or a PDF with the dimensions. I am surprised this is not included in the pack. Regards, Alan
Anonymous
Not applicable
Hi Can someone give me the link or attach the Allegro PCB files for the XC702 Development Card. Thanks Regards, Alan
Scholar pratham
@Anonymous
-Pratham
Anonymous
Not applicable
That is super!, Thanks for your help.
Newbie csawyer
Can I revive this thread? I also need board dimensions for the ZC702 eval board. The link provided to OP does not work for me and appears to be inactive. Can you provide a sketch/drawing .pdf showing mechanical dimensions (location and tolerance) of FMC1/FMC2 connector and connector mounting holes? Thanks.
@csawyer
Kind request:This forum post is very old and created long time back.  Please do not post any further queries /replies for this forum post. If there are any follow on questions with regards to this issue please post a new query. For reference purpose if you wish you may add this old forum link in your new forum post query.
Please follow below steps for your requirement
1) Open the following Zc702 boards link. https://www.xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html#documentation
2) Find "Documentation type" box in left side. Check the box "Board Files". You can find all board files documents including "rdf0170-allegro board files source".
3) Download  required allegro board file after registration and sign-up
4) Unzip and open that board file in Allegro free Viewer. From that you can find all dimensions of the board.
Do you have a new link to the mechanical dimensions or 3D CAD files of Zynq-7000 SoC ZC702?  Thank you.
