booting prebuilt ubuntu desktop on zcu102 failed
I am trying to boot the prebuilt ubuntu desktop on my zcu102 using petalinux 2018.3 but have not had any success. I followed the instructions here first compiling the kerenl and later using prebuilt. On both attempts, the uboot prompt would complain ## Error: "sdbbot" not defined" :
Terminal ready
Xilinx Zynq MP First Stage Boot Loader
Release 2018.3 Mar 21 2019 - 10:07:41
NOTICE: ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x10080000
NOTICE: BL31: v1.5(release):xilinx-v2018.2-919-g08560c36
NOTICE: BL31: Built : 10:05:01, Mar 21 2019
PMUFW: v1.1
U-Boot 2018.01 (Mar 21 2019 - 10:05:55 +0000) Xilinx ZynqMP ZCU102 rev1.0
I2C: ready
DRAM: 4 GiB
EL Level: EL2
Chip ID: zu9eg
MMC: mmc@ff170000: 0 (SD)
SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 MAC addresses don't match:
Address in ROM is 01:02:03:04:05:06
Address in environment is 00:0a:35:00:22:01
eth0: ethernet@ff0e0000
## Error: "sdboot" not defined
Here is my env variables on uboot prompt:
ZynqMP> printenv
arch=arm
autoload=no
baudrate=115200
board=zynqmp
board_name=zynqmp
boot_img=BOOT.BIN
boot_targets=mmc0
bootcmd=run sdboot
bootdelay=10
bootenv=uEnv.txt
bootenvsize=0x40000
bootenvstart=0x1e00000
botcm=run sdboot
botcmd=run sdboot
clobstart=0x10000000
console=console=ttyPS0,115200
cp_kernel2ram=mmcinfo && fatload mmc ${sdbootdev} ${netstart} ${kernel_img}
cpu=armv8
default_bootcmd=run uenvboot; run cp_kernel2ram && bootm ${netstart}
dfu_mmc_info=set dfu_alt_info ${kernel_image} fat 0 1\\;dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0
dfu_ram=run dfu_ram_info && dfu 0 ram 0
dfu_ram_info=setenv dfu_alt_info image.ub ram $netstart 0x1e00000
dtb_img=system.dtb
dtbnetstart=0x23fff000
eraseenv=sf probe 0 && sf erase ${bootenvstart} ${bootenvsize}
ethaddr=00:0a:35:00:22:01
fault=echo ${img} image size is greater than allocated place - partition ${img} is NOT UPDATED
fdtaddr=1280000
fdtcontroladdr=7fe7d4b0
fileaddr=1400000
filesize=c8190
importbootenv=echo "Importing environment from SD ..."; env import -t ${loadbootenv_addr} $filesize
initrd_high=0x0
install_boot=mmcinfo && fatwrite mmc ${sdbootdev} ${clobstart} ${boot_img} ${filesize}
install_jffs2=sf probe 0 && sf erase ${jffs2start} ${jffs2size} && sf write ${clobstart} ${jffs2start} ${filesize}
install_kernel=mmcinfo && fatwrite mmc ${sdbootdev} ${clobstart} ${kernel_img} ${filesize}
jffs2_img=rootfs.jffs2
kernel_img=xen.ub
load_boot=tftpboot ${clobstart} ${boot_img}
load_dtb=tftpboot ${clobstart} ${dtb_img}
load_jffs2=tftpboot ${clobstart} ${jffs2_img}
load_kernel=tftpboot ${clobstart} ${kernel_img}
loadaddr=0x10000000
loadbootenv=load mmc $sdbootdev:$partid ${loadbootenv_addr} ${bootenv}
loadbootenv_addr=0x00100000
modeboot=sdboot
nc=setenv stdout nc;setenv stdin nc;
netboot=tftpboot ${netstart} ${kernel_img} && bootm
netstart=0x10000000
psserial0=setenv stdout ttyPS0;setenv stdin ttyPS0
sd_uEnvtxt_existence_test=test -e mmc $sdbootdev:$partid /uEnv.txt
sd_update_dtb=echo Updating dtb from SD; mmcinfo && fatload mmc ${sdbootdev}:1 ${clobstart} ${dtb_img} && run install_dtb
sd_update_jffs2=echo Updating jffs2 from SD; mmcinfo && fatload mmc ${sdbootdev}:1 ${clobstart} ${jffs2_img} && run install_jffs2
sdbootdev=0
serial=setenv stdout serial;setenv stdin serial
serverip=192.168.2.2
setup=setenv partid auto
soc=zynqmp
stderr=serial@ff000000
stdin=serial@ff000000
stdout=serial@ff000000
test_crc=if imi ${clobstart}; then run test_img; else echo ${img} Bad CRC - ${img} is NOT UPDATED; fi
test_img=setenv var "if test ${filesize} -gt ${psize}; then run fault; else run ${installcmd}; fi"; run var; setenv var
thor_mmc=run dfu_mmc_info && thordown 0 mmc 0
thor_ram=run dfu_ram_info && thordown 0 ram 0
uenvboot=if run sd_uEnvtxt_existence_test; then run loadbootenv; echo Loaded environment from ${bootenv}; run importbootenv; fi; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi
update_boot=setenv img boot; setenv psize ${bootsize}; setenv installcmd "install_boot"; run load_boot ${installcmd}; setenv img; setenv psize; setenv installcmd
update_dtb=setenv img dtb; setenv psize ${dtbsize}; setenv installcmd "install_dtb"; run load_dtb test_img; setenv img; setenv psize; setenv installcmd
update_jffs2=setenv img jffs2; setenv psize ${jffs2size}; setenv installcmd "install_jffs2"; run load_jffs2 test_img; setenv img; setenv psize; setenv installcmd
update_kernel=setenv img kernel; setenv psize ${kernelsize}; setenv installcmd "install_kernel"; run load_kernel ${installcmd}; setenv img; setenv psize; setenv installcmd
vendor=xilinxariables on uboot:
I appreciate if someone can provide me some pointers. Thanks in advance.
