difference between Evaluation Kit "EK-K7-KC705-CES-G" and Evaluation Kit "EK-K7-KC705-G"
hallo everyone,
can someone tell me the difference between Evaluation Kit "EK-K7-KC705-CES-G" and Evaluation Kit "EK-K7-KC705-G".
what does "CES" stand for?
thanks in advance.
best regards
lei
CES stands for Common Engineering Sample and the later one is production
Please check this link for more info
http://www.xilinx.com/support/answers/37579.html
Commercial temperature grade, engineering sample.
During the release fo parts to production, markings represent what stage the procesws was in:
ES - engineering samples (test program and characterization in process)
CES - (or IES) tested for commercial temperature ( or industrial temperature range), meeting specifications in the data sheet
C, I (M, A) - in production (production qualified)  Meets all specifications.
Austin Lesea
Principal Engineer
Xilinx San Jose
