Observer malharjere
$display function question
I have a Kintex KC705 with Vivado 2017.4. I have a binary file called "malharjere" that is 10 bytes long and contains the string "malharjere". I have the following code to load it into memory:
module PRBG(a,b);
input a;
output reg b;
reg[9:0] data[7:0];
initial $readmemh("malharjere", data);
integer i;
initial begin
$display("rdata");
for (i = 0; i < 8; i=i+1)
$display("%d: %h", i, data[i]);
end
always @ (posedge a) begin
b <= $random(a);
end
endmodule
module PRBG(a,b);
input a;
output reg b;
reg[9:0] data[7:0];
integer i;
initial begin
$display("rdata");
end
b <= $random(a);
end
endmodule
When I synthesize, implement and open the RTL schematic, I don't see the hex values for "malharjere" anywhere in my schematic. Additionally, when I print them to console using the $display function I don't see the values appear anywhere on the Tcl console. Am I missing something here? How do I see the hex values of the file I uploaded in RTL schematic or in the Tcl console?
Mentor watari
Mentor
Re: $display function question
Hi @malharjere
First of all, $display function doesn't support synthesis, implement. It only support simulation.
I suggest to implement BRAM with initial data and/or randomize logic, if you want to do.
Best regards,
