kvkhekale
image_echo_test not running (getting stucked) on zybo
Hello
I am trying to run pre-built application image_echo_test on zybo using openamp.
I have followed all the steps as per UG1186 as well as edited the device tree and copied the BOOT.bin, image.ub, system.bit, zynq_fsbl.elf and system.dtb fles on BOOT partition on SD card.
The linux on SD card boots well.
But when I try to run the image_echo_test by giving "echo" command, it gets stucked at "Booting fw image image_echo_test"
Only the remoteproc driver is getting installed at startup, but not "virtio" driver.
Not able to find out the step I am missing in the overall procedure.
Please guide me for the above problem.
Attaching the error screenshot with this post
