10-03-2019 04:06 AM
I have project which is model in 2016.2 in xilinx version. I install 2019.1 and run that project. In ISE or Vivado all thing going well but when i launch it in SDK, it is not working and in project manger only i see hdf file folder, it nver show me stanalone_bsp_0 folder.
Can you guide me how to do it in SDK.
10-07-2019 08:16 AM
Were you able to try the steps mentioned except update to 2019.1?
I imagine the steps would be similar except use the versions you are asking about.
10-04-2019 03:00 PM
Hi @nwp-100,
This forum discusses how to migrate from SDK2016.4 to SDK2018.3 and the steps are italicized below.
I would recommend these steps:
This will make sure that all the dependencies are accounted for.
Hope this helps!
Sincerely,
Courtney
Please don’t forget to reply, give kudos, and accept as a solution if you found this helpful!
10-06-2019 09:01 PM
I need for 2019.1 version, i working on that and install only 2019.1 xilinx version.
10-07-2019 08:16 AM
