black_flowers
problem accessing spartan3e starter kit leds using coolrunner2.
im'm trying to make a flashing led with spartan 3e starter kit, using coolrunner2. I had it done using spartan3e but i can't find ucf file for coolrunner2. Is it possible working with leds using coolrunner2? (in spartan 3e development kit) i mean ¿are the pins of coolrunner2 physically connected to leds?
thanks
Hi Black_Flowers,
From memory, been a while since I played with that board, the CPLD can be accesses but its primary function is to act as the USB interface for the dev board, allowing you to prog the FPGA without having to buy the USB JTAG download cable.
My view was I bought a 3E board, I left the CPLD alone partly because I didn’t want to break the function and partly because I wasn’t that interested in the CPLD…
If you want to play with the CPLD you could use the FPGA to connect the CPLD to the LED’s switches etc.
Bobster
Just thinking out loud, I’d say no you cant, but you could check out the diagram on the xilinx site
Bobster
black_flowers
i'v checked the diagram, and i had only seen cpld pins connected to spartan3e pins. So it seems there's no physical connection of cpld pins with leds,buttons,switches etc, on the "spartan 3e starter kit board" (that's the reason why i'm asking here, since it seems the cpld is useless on this board).
thanks
Hi Black_Flowers,
Bobster
