soDIMM recommended in XTP504 and UG1267 for ZCU104 is obsolete
The soDIMM (micron mta8atf51264hz-2g6) recommended in XTP504 (last updated 2/27/2019) and UG1267 (last updated 10/9/2018) for the ZCU104 is obsolete.
These documents recommend micron mta8atf51264hz-2g6 via a dead link in XTP504.
Answer record 71961 which addresses two different dev cards, the ZCU102 and ZCU106, does not mention the ZCU104.
However, answer record 71961 does mention the same obsolte MTA8ATF51264HZ-2G6B1 mentioned in ZCU104 documentation.
Request:
1.  Please update XTP504 with suitable non-obsolete MPN for PL-side DDR4 soDIMM
2.  Please update UG1267 with suitable non-obsolete MPN for PL-side DDR4 soDIMM
3.  Please provide design files and MIG settings for the ZCU104
Obviously, this will allow Xilinx customers to not each re-engineer MIG settings and research parts, which of course delays project schedules, especially since not every person purchasing the ZCU104 will be as adept as Xilinx at using the MIG.
Thanks!
Welcome back!
markg@prosensing.com wrote:
Welcome back!
Thanks.  But I'm sad my post was ignored. :(
I am also attempting to integrate a PL DDR4 in the ZCU104.  I have found the 'custom_parts' .CSV file, but there are many fields in the document that I just don't know the answers to.  For a board like ZCU104 I think that many of these are fixed, and only a few fields will change between vendor memories (size, timing, etc).
Can we get a little more information to help?
-Brian
Hi everyone,
Check out this forum and see if it helps answer some questions!
https://forums.xilinx.com/t5/Evaluation-Boards/PL-Side-SoDimm-recommendations-for-ZCU104-dev-kit/m-p/1015493/highlight/false#M24028
Sincerely,
Courtney
Please don’t forget to reply, give kudos, and accept as a solution if you found this helpful!
Can you please explain why it took so long to answer?
I'll check back in January for your reply.
