diannaoyoujian
zcu102 update msp430 frimware failed
I want use zcu102-scui to update msp430 firmware on zcu102 board.But it is failed at step0 and step3(I have set SW6 to 0-on on on on,attach two jumpers across J164 as shown in xtp433)。How can I fix it?My email is sjxu@stu.xidian.edu.cn
BR!
vatsalt
Please refer the below link to check the forum post with similar issue and apply the mentioned workarounds.
https://forums.xilinx.com/t5/Xilinx-Evaluation-Boards/XTP433-running-BIT-exe-from-zcu102-scui-flash-restore-to-update/td-p/1002889
Let me know if the issue persists.
Best Regards,
Vatsal
diannaoyoujian
I read all content in the link,but there is no method to resolve the problem in the link.
BR!
diannaoyoujian
I resolve the problem according to the below link
https://forums.xilinx.com/t5/Xilinx-Evaluation-Boards/ZCU102-firmware-not-updating/m-p/914160#M19897
Thanks for your help!
BR
anatoli
Hello @diannaoyoujian ,
Thanks a lot for letting us know. Glad to hear that you've managed to overcome your issue.
As your issue is solved now, can you please mark a response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then?  We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
