Pablo1610
AXI DMA diferent transfer sizes send/receive
I am wondering how can I sent over the DMA a 9 element (32 bits per element) vector and receive only 1 elements?
I want to receive only 1 elements because I am sending the data from memory over the axi strem interface of the DMA to an accumulator so the result its only one 32 bit number.
I want also to do it by polling mode and a simple DMA, but it gets stuck in the busy DMA while loop
Status = XAxiDma_SimpleTransfer(&AxiDma,(UINTPTR) RxPtr,
                                9, XAXIDMA_DEVICE_TO_DMA);
if (Status != XST_SUCCESS) {
	return XST_FAILURE;
Status = XAxiDma_SimpleTransfer(&AxiDma,(UINTPTR) TxPtr,
		         	1, XAXIDMA_DMA_TO_DEVICE);
	return XST_FAILURE;
while ((XAxiDma_Busy(&AxiDma,XAXIDMA_DEVICE_TO_DMA)) ||
        (XAxiDma_Busy(&AxiDma,XAXIDMA_DMA_TO_DEVICE))) {
	/* Wait */
dgisselq
@Pablo1610 ,
Hold TLAST high, and you'll only ever transfer a single stream element.
Dan
Pablo1610
@dgisselq
I cannot hold TLAST high because it is the signal to know when the accumulator has all the values to compute the output.
dgisselq
@Pablo1610 ,
This would be on the accumulator's output, not it's input.
Dan
Pablo1610
@dgisselq
Okey, you are rigth, becuase it will say it is always the unique and last element. But I think, it won't fit when I will increase the output to more than one element in order to increase the throughtput.
dgisselq
@Pablo1610 ,
The S2MM controller you are using was designed for handling network packets where the outgoing length is unknown.  Just make sure that the S2MM controller is set for a greater (or equal) length than you need, then set TLAST on the last word of the packet.  The S2MM controller will then stop early.  This is what you want, right?
You'll also want to make certain that the outgoing TVALID isn't set until you get to the value you actually want to send.
Dan
