Observer john
AXI Stream clock converter with FIFO
I have an AXI-Stream FIFO connected to another vhdl module working at a different frequency, with an AXI-Stream clock converter between them to handle the clock domain crossing.
The AXI-Stream FIFO is filled with the words 0xa,0xb,..0xc by a CPU connected to its AXI-Lite port.
On the other side of the fifo, after the clock convertsion I see following timings:
AXI_STR_TXD_* are the output signals of the fifo, while the rx_* are the signals after the clock converter.
It can be seen how the data output of the clock converter (rx_tdata) is not correct: even though tvalid and tready are both asserted, each word is present on the bus for a different number of clk cycles (e.g. 0xb is there for much longer than 0xc).
This is more or less what I would expect if the clock converter was simply synchronizing the signals form a clock domain to the other, with the two clocks asyncronous and the destination clock faster than the source clock. But this would make its output useless in its intended application.
Am I using the clock conversion core improperly? I know there is also a dual-clock "AXI-Stream data FIFO" that works well in this case, but I also need the AXI-lite port for the CPU.
Scholar dgisselq
Re: AXI Stream clock converter with FIFO
@john,
Just a quick question which may or may not be related, but ... how long are you holding the AXI components in reset before releasing them?
Dan
Observer john
The reset is asserted by a "processing system reset" core, its external reset input lasts 5 clk cycles of the slowest clock.
Scholar dgisselq
Xilinx recommends a minimum of 16 clocks of reset.  Can you see if that changes anything?
Dan
Observer john
well that's weird, I can't reproduce this issue anymore. I don't remember exatly but I believe I just restarted vivado and regenerated the AXI fifo and clock converter.
Thanks anyway for your suggestion, I will extend the reset to comply with the suggested implementation practices.
