song0201
Aurora 8b10b User Clk
hello.
 using Vivado2018.2
I used Aurora 8b10b ipcore(took it from example design source) ,
but the user clk(output) didn't come out .
setting my input value
refclk = 120MHz , initclk=60MHz, drpclk=60MHz
but i looking through ila , tx done and rx done,tx lock  are highed.reset ,gt reset are lowed.
 hard err is low ,but intermittently high
Is there anything else I need to see? Which one should I see?
Give me a solution.
rkhatri
Hi @song0201,
Please test the transceiver by using IBERT design. This will make sure GT are working fine.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
