10-27-2013 11:37 PM
i am using virtex 4 and BRAM from Nalltech kit .....
i am writing data of an array of 8x512 values of 32 bit unsigned integer ,i am not able to read some specific value from a location like last 50 elements of first array (data[0][512]) are read as garbage values and first 20 elements of 2nd array (data[1][512]) are also the same and the rest of the data is read fine ....
please can any one help me with this problem .....Thanks in advance....
10-28-2013 08:47 AM
Is this in simulation or hardware?
Can you share your memory accessing logic/testcase/waveform shanpshots so that we may give any clues?
Vanitha.
10-30-2013 01:25 AM
You can try with fixed primitve option during core generation.
What is your configuration minimum area, low power, fixed primitive.
