Observer alen89
Block memory generator in mode true dual port
Dear,
I am using block memory generator 8.4 to instanciate a true dual port ram in stand alone mode over an ultrascale device(XCZU3EG).
I am using a bram axi controller in port A and user defined in port B. I simulate the design with modelsim and the write and the behaviour of the FSM that I am using to write work properly. But when I generate the binary files I neve see nothing written in the memory. I always can write and read from the port that is connected to the mpsoc but never with the FSM.
What could it be the problem?.
Find attached also the captures of configuration.
Best,
Alen.
Re: Block memory generator in mode true dual port
Hi @alen89
The first debugging step should be to add bebug probes and monitor if proper transactions happening on below signals or not
doutb
addrb
dinb
web
Observer alen89
I did already, in fact I have a debug port to check if the FSM is moving on states.. And when I dump the ram I saw 2 positions written.. but not the good ones.. Could be that is not enough for write one clock cycle?..
Teacher drjohnsmith
you have simulated , which is a great place to start, amazing how many people dont,
Second up is do you have timing constraints and are they meet ?
If not, you need to fix that first, no point going to hardware with out constraints, or broken constraints,
Observer alen89
"you have simulated , which is a great place to start, amazing how many people dont"
if not at least me, I could become crazy if I dont simulate :D
"Second up is do you have timing constraints and are they meet ?"
The report timing does not complain nothing about the ram or the modules related to this part of the design.. I am trying with a simple fsm to check..
Teacher drjohnsmith
do i take it u do have timing fail then,
fix that first
