dmitryl_home
CAN-FD Config & Zynq Interface
Hi All,
What's the basic (minimal) configuration that should be done for the CAN FD IP?
I mean what control registers should be written and what values?
In case of connection two CAN-FD IPs one to another on the same shared line, should both IPs be configured with the same vaules?
How to connect two CAN FD IPs to Zynq?
Thank you!
