Way
Can Aurora 64b/66b init clk in Ultrascale devices is set to higher value?
In the PG074, there mentioned that the init clk range from 50Mhz to 200Mhz. However, the init_clk is set to line rate/64 for Ultrascale devices and the GUI showed the linerate/64 as the maximum frequency for init_clk in Aurora 64b/66b IP. May I know is it possible if we can assign a reference input clock to init_clk that is higher than the clock frequency mentioned in the GUI?
For example, a 6.25Gbps linerate is having init_clk frequency of (6.25G/64 = 97.65625M). Is it ok if i assign 100Mhz to it instead?
rkhatri
Hi @Way,
Range of frequency which init clock can take is shown in IP GUI. Please provide clock under that limit.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
Way
Hi @rkhatri
Noted and thank you
