sunndesai3333
Change the prot signals (Trustzone) of AXI_DMA
I have an AXI_DMA 7.1 in a block design with ZYNQ_PS on ZCU102. There is a possibility that the DMA is configured in a secured mode and I want to set the NS bit: bit [1] of ar_prot[2:0] of M_AXI_MM2S (output of DMA). I could not find the configuration in the DMA IP. Can I get some help on this?
