acc-iot
Create verilog simulation file with Block Memory Generator 8.4
I am working under Vivado v.2020.01. I have generated a RAM with the Block Memory Generator 8.4, and when I look into the ip output folder, I can only see a blk_mem_gen_0_stub.v verilog file, and a blk_mem_gen_0.veo file, which are only for instanciation purposes, not simulation purposes.
I can see in the header of the stub file that it was generated by some internal command of blk_mem_gen : write_verilog -mode synth_stub.
Is there any way for me to generate a complete verilog simulation model of my memory ?
Alex
acc-iot
Hello zhangfeng,
Thanks for your answer. I have found the necessary verilog simulation files for the generated RAM block as follows:
- myproject.srcs/sources_1/ip/myRAM/sim/myRAM.v
- myproject.srcs/sources_1/ip/myRAM/simulation/blk_mem_gen_v8_4.v
With these files,I can now run simulation outside of Vivado environment, with another vendor simulator which was my initial target.
My problem is solved
zhangfeng
Hello, @acc-iot .
Use the file under the "simulation" folder.
If there are undefined modules in that file,
comile your own simulation libraries by choosing "Compile Simulation Libraries..." under "Tools" in Vivado.
acc-iot
Hello zhangfeng,
