esakki@babu
Custom IP
How to add IP in Xilinx EDK ?
How to create Custom IP in Xilinx EDK?
If I create a custom IP using Vivado,  will it suitable for Xilinx EDK ?
esakki@babu
Please answer this
How to Create custom IP in Xilinx ISE? I have HDL file, I need to  convert into IP.
otherwise, Is custom IP created by Vivado and will it support to Xilinx ISE?
Please answer!!!!
dpaul24
esakki@babu ,
For Vivado - https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1118-vivado-creating-packaging-custom-ip.pdf
For ISE - https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/cgn_p_create_custom_core.htm
More help - https://forums.xilinx.com/t5/Synthesis/Making-and-using-own-IP-on-ISE/td-p/731456
I simply found this by searching using this phrase - Xilinx ISE custom IP create
You can also do something alike!
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
esakki@babu
Yes, in vivado able to create custom IP.
My doubt, will it support to Xilinx ISE, EDK?
dpaul24
esakki@babu ,
Yes. Have just updated my answer.
esakki@babu
How to add IP in Xilinx ISE, EDK?
