m.knam
ECC v2.0 Generator matrix
Hello all,
I want to use the ECC v2.0 IP core with 64 bit Hamming Code. I checked the product guide and searched on the internet but didn't find the generator/check matrix of the different codes. Is that a secret or can I know it? Unfortunately I can't use the Core if I can't make it compatible with other devices like for example microcontrollers where I can't use the IP Core for obvious reasons.
While searching I found this app note (645) with a 64 bit Hamming code with the same properties as the IP Core. Is the generator matrix used in this app note and in the zip file the same as in the IP Core?
Thanks in advance
zhangfeng
Hello, @m.knam .
Have you sloved the problem?
