ERROR: [VRFC 10-2063] Module not found while processing module instance
I am working on a project which needs Axi stream FIFO from uram. I am instantiating xpm_fifo_axis in my wrapper module in Vivado 2018 .1. While simulating am getting the fillowing message:
ERROR: [VRFC 10-2063] Module not found while processing module instance [D:/XRAN/design/axi_ufifo/axi_ufifo.srcs/sources_1/new/axi_ufifo.v:356] ERROR: [XSIM 43-3322] Static elaboration of top level Verilog design unit(s) in library work failed.
could you please help me with this issue.
Thanks in advance
Gayathri
Hi @gayathri_nair
Please refer to this AR
https://www.xilinx.com/support/answers/56492.html
Reply if you have any queries , Give Kudos and accept as solution
