Keerthi
FIFO Generator
I am using 13.2, if i generate the IP in windows and linux, but only in windows it has option to provide a different write and read width while in linux it is not letting me modify read width, it is taking it to be equal to write width. Is there any thing else as the version of vivado and fifo generator all are the same in windows and linux.
Keerthi
pthakare
Hi @Keerthi
It should be same in Linux and Windows .
Can you please confirm if you are enabling the "Asymmetric port width" option in GUI.?
If So please let me know following details
#1 VIVADO version you are using?
#2 Device part number
You can share .xci as well which can confirm #1 and #2
#3 OS details for Linux.
Reply if you have any queries, give kudos and accept as solution
Keerthi
Hi Pthakare,
Thank you, i had missed that.
Keerthi
