Fast-Fourier-Transform IP 9.1 no autogenrated VHDL testbench?
As stated in the doc PG-109 , Page 85 - there is supposed to be an autogenerated testbench when we generate the FFT IP core.
After synthesis of my design -  I see no demo_tb/tb_<component_name>.vhd file in the <compoent_name>.runs/ folder.
├── design_1_xfft_0_0_synth_1
│ ├── design_1_xfft_0_0.dcp
│ ├── design_1_xfft_0_0.tcl
│ ├── design_1_xfft_0_0_utilization_synth.pb
│ ├── design_1_xfft_0_0_utilization_synth.rpt
│ ├── design_1_xfft_0_0.vds
│ ├── dont_touch.xdc
│ ├── gen_run.xml
│ ├── htr.txt
│ ├── ISEWrap.js
│ ├── ISEWrap.sh
│ ├── project.wdf
│ ├── rundef.js
│ ├── runme.bat
│ ├── runme.log
│ ├── runme.sh
│ ├── __synthesis_is_complete__
│ ├── vivado.jou
│ └── vivado.pb
├── impl_1
│ ├── design_1_wrapper_61683.backup.vdi
│ ├── design_1_wrapper.dcp
│ ├── design_1_wrapper_drc_opted.pb
│ ├── design_1_wrapper_drc_opted.rpt
│ ├── design_1_wrapper_drc_opted.rpx
│ ├── design_1_wrapper.hwdef
│ ├── design_1_wrapper_opt.dcp
│ ├── design_1_wrapper.tcl
│ ├── design_1_wrapper.vdi
│ ├── gen_run.xml
│ ├── htr.txt
│ ├── init_design.pb
│ ├── ISEWrap.js
│ ├── ISEWrap.sh
│ ├── opt_design.pb
│ ├── place_design.pb
│ ├── project.wdf
│ ├── rundef.js
│ ├── runme.bat
│ ├── runme.log
│ ├── runme.sh
│ ├── vivado_61232.backup.jou
│ ├── vivado_61683.backup.jou
│ ├── vivado.jou
│ └── vivado.pb
└── synth_1
├── design_1_wrapper_utilization_synth.pb
├── design_1_wrapper_utilization_synth.rpt
├── design_1_wrapper.vds
├── dont_touch.xdc
├── gen_run.xml
├── htr.txt
├── ISEWrap.js
├── ISEWrap.sh
├── project.wdf
├── rundef.js
├── runme.bat
├── runme.log
├── runme.sh
├── vivado.jou
└── vivado.pb
 <compoent_name>.runs folder structure is shown above. <compoent_name>.ip_user_files/ does not have the mentioned vhd file too.
I am unable to find the vhdl testbench anywhere in the project folder - even after place_design. The only place I find some mention of it is in : <Xilinx Install dir>/2019.1/data/ip/xilinx/xfft_v9_0/ttcl/testbench_vhdl.ttcl, which is encrypted.
You are correct, when FFT IP is added to the bd design, the generated outputs of FFT IP does not have the demo test bench.
If you want to get the demo test bench of FFT IP, open Vivado IP Catalog, find FFT IP, click "customize IP", Configure IP, then click "okay" to generate IP, you can get the demo test bench.
Please Kudo or Accept as a solution, If this Post helped you.
The demo_tb/tb_<component_name>.vhd file is geneated along with the IP, so, when you have configure FFT IP parameters and click okay to generate the IP, after the IP generation is completed, you can find the demo test bench, which should be located in the generated IP directory.
Sadly, no - I couldn't find it after generating the block design per IP.
├── bd
│   └── design_1
│   ├── ip
│   │   └── design_1_xfft_0_0
│   │   ├── design_1_xfft_0_0_sim_netlist.v
│   │   ├── design_1_xfft_0_0_sim_netlist.vhdl
│   │   └── sim
│   │   └── design_1_xfft_0_0.vhd
│   └── sim
│   ├── design_1.protoinst
│   └── design_1.v
├── README.txt
└── sim_scripts
└── design_1
├── activehdl
│   ├── compile.do
│   ├── design_1.sh
│   ├── design_1.udo
│   ├── file_info.txt
│   ├── glbl.v
│   ├── README.txt
│   ├── simulate.do
│   └── wave.do
├── ies
│   ├── design_1.sh
│   ├── file_info.txt
│   ├── glbl.v
│   ├── README.txt
│   └── run.f
├── modelsim
│   ├── compile.do
│   ├── design_1.sh
│   ├── design_1.udo
│   ├── file_info.txt
│   ├── glbl.v
│   ├── README.txt
│   ├── simulate.do
│   └── wave.do
├── questa
│   ├── compile.do
│   ├── design_1.sh
│   ├── design_1.udo
│   ├── elaborate.do
│   ├── file_info.txt
│   ├── glbl.v
│   ├── README.txt
│   ├── simulate.do
│   └── wave.do
├── README.txt
├── riviera
│   ├── compile.do
│   ├── design_1.sh
│   ├── design_1.udo
│   ├── file_info.txt
│   ├── glbl.v
│   ├── README.txt
│   ├── simulate.do
│   └── wave.do
├── vcs
│   ├── design_1.sh
│   ├── file_info.txt
│   ├── glbl.v
│   ├── README.txt
│   └── simulate.do
├── xcelium
│   ├── design_1.sh
│   ├── file_info.txt
│   ├── glbl.v
│   ├── README.txt
│   └── run.f
└── xsim
├── cmd.tcl
├── design_1.sh
├── file_info.txt
├── glbl.v
├── protoinst_files
│   └── design_1.protoinst
├── README.txt
├── vhdl.prj
└── vlog.prj
I'm petty sure the demo test bench is there. Assume you create a vivado project named "project_1". Assume the FFT IP core is named "xfft_0", the FFT IP demo test bench is located at \project_1.srcs\sources_1\ip\xfft_0\demo_tb.
├── design_1.bd
├── design_1.bxml
├── design_1_ooc.xdc
├── hdl
│   └── design_1_wrapper.v
├── hw_handoff
│   ├── design_1_bd.tcl
│   └── design_1.hwh
├── ip
│   ├── design_1_xfft_0_0_ooc.xdc
│   ├── design_1_xfft_0_0_stub.v
│   ├── design_1_xfft_0_0_stub.vhdl
│   ├── design_1_xfft_0_0.xci
│   ├── design_1_xfft_0_0.xml
│   ├── sim
│   └── synth
├── ipshared
│   ├── 1123
│   │   └── hdl
│   │   └── xbip_utils_v3_0_vh_rfs.vhd
│   ├── 1971
│   │   └── hdl
│   │   └── axi_utils_v2_0_vh_rfs.vhd
│   ├── 3c11
│   │   └── hdl
│   │   └── xfft_v9_1_vh_rfs.vhd
│   ├── 5204
│   │   └── hdl
│   │   └── cmpy_v6_0_vh_rfs.vhd
│   ├── 7468
│   │   └── hdl
│   │   └── xbip_pipe_v3_0_vh_rfs.vhd
│   ├── 910d
│   │   └── hdl
│   │   └── xbip_dsp48_addsub_v3_0_vh_rfs.vhd
│   ├── cbe4
│   │   └── hdl
│   │   └── c_addsub_v12_0_vh_rfs.vhd
│   ├── cd8a
│   │   └── hdl
│   │   └── c_shift_ram_v12_0_vh_rfs.vhd
│   ├── cdbf
│   │   └── hdl
│   │   └── xbip_dsp48_wrapper_v3_0_vh_rfs.vhd
│   ├── cfdd
│   │   └── hdl
│   │   └── xbip_addsub_v3_0_vh_rfs.vhd
│   ├── d367
│   │   └── hdl
│   │   └── xbip_bram18k_v3_0_vh_rfs.vhd
│   ├── d4d2
│   │   └── hdl
│   │   └── mult_gen_v12_0_vh_rfs.vhd
│   ├── e8d9
│   │   └── hdl
│   │   └── floating_point_v7_0_vh_rfs.vhd
│   ├── ecb4
│   │   └── hdl
│   │   └── c_mux_bit_v12_0_vh_rfs.vhd
│   └── edec
│   └── hdl
│   └── c_reg_fd_v12_0_vh_rfs.vhd
├── sim
│   └── design_1.v
├── synth
│   ├── design_1.hwdef
│   └── design_1.v
└── ui
└── bd_1f5defd0.ui
This is the output of ~/workspace/PHOTONIC/FFT-vivado/project_2_FFT_trash/project_2_FFT_trash.srcs/sources_1/bd/design_1
