greenghecco
Fastest Dual Clocked Fifos
is there any advisement which is the fastest dual cloked Fifo (Block Ram, Distributed Ram or Built-in FIFO)?
Thanks for helping.
balkris
Built-in FIFO has better performance and Block ram FIFO because of Access time. Again Distributed FIFO slower then built in FIFO and faster then Block RAM.
I think FIFO selection depends upon number of things. If you need higher depth FIFO better to use block based FIFO.
Built in FIFO only available in Virtex devices
Thanks and Regards
Balkrishan
rcingham
Which FPGA?
How big is your FIFO?
"If it don't work in simulation, it won't work on the board."
greenghecco
Virtex6 lx240t, Fifo Size just 16 Bit width and 16 entries
balkris
Thanks and Regards
Balkrishan
