joe306
Generate a sinewave using a Numerically Controll Oscillator
Hello, I want to generate a 16 bit data that is a sine wave using a Numerically Controlled Oscillator. Does the IP Catalog have anything that can do this? I want to use the output of the NCO and multiply it by a User Controlled Constant to dynamically adjust the amplitude of the sine wave.
Thank you,
Joe
bruce_karaffa
Look for the DDS Compiler in the IP catalog.
bruce_karaffa
