How to separate clock
I want to separate a differential clock to two and connect the clocks to two modules. Is there any IP core can do that?
Teacher drjohnsmith
Re: How to separate clock
nope
Im assumin gthe two modules are IP in the same FPGA ?
inside the fpga all signals are single ended,
   you use the differential IO to conveert to single ended,
What IP do you want to do this with ?
   I ask  as some IP such as the MMCM, and the SerDes blocks have very specific pins that have to connect to, to achieve best performance.
I solved the problem by using a wizard to generate all clocks. Thank you so much for your reply.
