How to use the ILA for AXI communication?
I try to debug the AXI communication but I´m strugeling with the ILA. According to this post the ILA clock frequency has to be at least the double of the signal clock frequency. But I cannot change the ILA clock frequency in the block design, because this will result in an error.
So how can I do it for AXI communications?
please read this topic:
https://forums.xilinx.com/t5/Adaptable-Advantage-Blog/AXI-Interface-Debug-Using-IP-Integrator/ba-p/794061
As for clock frequency can't you just use pll to double the frequency ?
Hi @kampi
I suggest using Set Up Debug tool (after the synthesis) to insert ILA cores. It is simpler and safer.
Thanks @ both of you. The link to the article was quite usefull.
