02-21-2021 03:28 AM
hello,
I've been struggling for over a month now with a xilinx IP and I can't get it to show signs of life. the IP is JESD204, and I couldn't find a working project anywhere. I'm using the evaluation license. scrolling through the posts I found this :" https://forums.xilinx.com/t5/Xilinx-IP-Catalog/JEDS204-Example-design-with-Vivado-2018-1/td-p/871614 ".
where, if i understood correctly, it says that the evaluation license is not working. i would like to know if this is true or i misunderstood.
02-22-2021 06:45 AM
I think the post you referenced is referring more to the "time-out" feature of an "Evaluation" license. With the proper version of the evaluation license, the design can target hardware but will timeout after a period of time. However, it sounds like your design is not working at all but not sure if it is in simulation or hardware.
You can reference the post below regarding which license you may have.
02-22-2021 06:45 AM
02-22-2021 09:08 AM
thanks for the clarification
