Stefano134
IP JESD204
i notice a problem with ip xilinx jesd204. i could not send data and receive them in any way, so i opened the example design of the transmitter (but the same problem is on the receiver) and i noticed that no data are sent, the test is completed, but i can not see where actually the data are sent.
also it seems that the jesd204b protocol is not respected, since the CGS phase is not performed, the only correct one is the ILAS phase. i attach the simulation. i am using vivado 2020.2 and 2019.2
could someone give me a hand, it is the seventh post that I make in the forum and in no one I got an answer. thanks
