IP JESD204B lanes mismatch tolerance
I would like to use the IP JESD204B, and I would like to know the mismatch tolerance on the PCB allowed between lanes in a same GTY (VUP) which can be compensated by the ILA by the ILA (Initial Lane Alignment )?
Hi @ba_moduleus ,
The JESD204B receiver core has been verified to function with a lane to lane skew of up to 8 octets.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
Hi @ba_moduleus ,
Rahul Khatri
Hi @rkhatri ,
Thanks for your answer.
