tchin123
Voyager
Voyager
IP license verification takes a long time
when I open a IP for the AXI_ethernet_subsyetm in Vivado 2018.2. It takes a very long time to locate or verify the license from the Custom IP Wizard. . Some time it takes a minutes and many other time it takes over 15 minutes. Any idea how i can fix this? besides This IP shouldn't requires a license any way.
watari
Hi @tchin123
Which type of license are you using in Vivado ? node-lock or license server ?
I suspect you describe unable license server on environment of LICENSE.
Would you make sure it ?
Best regards,
tchin123
Voyager
Voyager
this is a license server, (floating) , the IP wizard runs with ot without of the server being on.
It will eventually run but the problem is that sometime it find it within a minute and sometime it take over 15 minutes
