JESD204C mode selection
Regarding "CTRL_RX_ILA_CFG0" from pg242, there is no option for JESD204C. How do I set this register?
rkhatri
Hi knam@jariettech.com ,
I believe register CTRL_RX_ILA_CFG0 is not available in JESD204C.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
nathanx
This register is not available for JESD204C IP.
This register also represents subclass type.
Are you sure this info in not available also?
Though CTRL_RX_ILA_CFG are read-only, "CTRL_TX_ILA_CFG" is R/W and this is only for "8B/10B". How do I configure "64B/66B" 204C parameters such as L/M/F/K... for RX & TX?
