mayank.ks
JTAG to axi master ip core issue
I am using "zybo z7 20" eval. board and i am trying to access Memory (DDR) using xilinx IP "JTAG to AXI Master v1.2" by using commands given below.
Read operation :
create_hw_axi_txn -quiet -force rd_tx [get_hw_axis hw_axi_1] -address 0x00000000 -len 1 -size 32 -type read
run_hw_axi -quiet rd_tx
get_property DATA [get_hw_axi_txn rd_tx]
Write operation :
create_hw_axi_txn -quiet -force wr_tx [get_hw_axis hw_axi_1] -address 0x00000000 -data 12345678 -len 1 -size 32 -type write
run_hw_axi -quiet wr_tx
So this is working fine but i want to read or write as a byte or hex instead of word so from my understanding what i have read from data sheet "-size" stands for size of a beat within a burst of axi transactions. For that i am using commands given below
e.g. :
for byte write
create_hw_axi_txn -quiet -force wr_tx [get_hw_axis hw_axi_1] -address 0x00000000 -data 45 -len 1 -size 8 -type write
for hex write:
create_hw_axi_txn -quiet -force wr_tx [get_hw_axis hw_axi_1] -address 0x00000000 -data 2345 -len 1 -size 16 -type write
for byte read :
create_hw_axi_txn -quiet -force rd_tx [get_hw_axis hw_axi_1] -address 0x00000000 -len 1 -size 16 -type read
for hex read :
But above commands is not working means i am not able to read and write for the same, So please help me how to read and write using JTAG to axi master
Mayank
klumsde
This question is already under investigation in this thread
https://forums.xilinx.com/t5/Processor-System-Design/JTAG-to-AXI-master-in-zynq-PL/m-p/1061878#M50442
Keith
