drexelmark
Matrix Operations for Virtex 6 using System generator
What options do I have if any, to implment Matrix Operations in System Generator for a Virtex 6?
Any suggestions on a way to approach this?
bwiec
drexelmark
No I haven't seen this.
What does it mean "All functions generated are compliant with the AXI4-Stream specification, facilitating system integration."?
AXI4-Strem?
Could this be somehow wrapped into System Genrator?
bwiec
AXI Stream is simply the interface used to communicate with the core. Most of our IP now have AXI interfaces.
Yes, you can use the black-box flow. This should be documented in UG640.
www.xilinx.com
balkris
You can use linear algebra took kit IP in coregen. In sysgen you can import this core with generated ngc file
Thanks and Regards
Balkrishan
