harshalrode
Need help in using IP cores in ISE
I want to use 2 IPs in a project FIFO and Memory interface. I am able to generate core for FIFO but how to generate both of them and use them together ?
are there any documents for coregen module use?
Thank you
luisb
You're going to have to have a top level file that instantiates both modules. If you want to use the FIFO within the MIG core then I recommend adding all the rtl to the design.
