sheladiya_vijay
Packet Classification in Virtex-5
We have used Virtex 5 FPGA device for our design. We want to implement packet classification on that. So during search I found Xilinx's CAM core which can be use for classification.
But when I went through it I came to know it can not classify range of data which is main thing for classification in our design.
Is there any possible solution for this in Virtex 5 device? If there is, please suggest.
Vijay
balkris
CAM IP discontinue by Xilinx you can use XAPP1151
www.xilinx.com/support/documentation/application_notes/xapp1151_Param_CAM.pdf
Thanks and Regards
Balkrishan
