RAMB18E cascade connectivity issue
I want to connect 3-RAMB18E2 modules in a cascaded fashion as shown in UG573 Page 23 Figure 1-11.
But I am not sure, how do I configure ports A and B.
for "FIRST" BRAM in cascade : I am using port DINBDIN for data input. Port A- read mode & Port B - write mode
for "MIDDLE" BRAM in cascade : I am using port CASDINB for input. Port A- read mode & Port B - write mode. My question is -
How do data read from Port A (FIRST BRAM) goes into CASDINB  of MIDDLE BRAM when FIRST BRAM port B is configured as WRITE??
Hi @gtushar
Standard Data out cascade and Data in cascade connectivity diagrams are given on page 20 to 23 of memory user guide
https://www.xilinx.com/support/documentation/user_guides/ug573-ultrascale-memory-resources.pdf
Additionally , What is the requirement of cascading memories here manually ? I mean is the specific reason for not using
block memory generator IP or XPM_Memory based implementation ?  Where cascading is done by tool itself.
Reply if you have any queries, Give Kudos and accept as Solution
