Storing floating point values in BRAM ipcore
I want to store a set of floating point values in BRAM from a COE file. How can I initialize the BRAM using these values? I have the coe file given below:
memory_initialization_radix=10;
memory_initialization_vector=
1.1,
1.1,
1,
1,
0,
0,
0,
0;
Whenever I try to do the same I am getting the error given below:
ERROR:sim - Invalid coefficient value 1.1 in COE file.
WARNING:sim - A core named 'BRAM_test' already exists in the project. Output
products for this core may be overwritten.
Resolving generics for 'BRAM_test'...
ERROR:sim - IP initializer could not set IP core parameters on IP model
ERROR:sim - Failed to initialize IP model.
ERROR:sim - Failed executing Tcl generator.
ERROR:sim - Failed to generate 'BRAM_test'. Failed executing Tcl generator.
Could anyone please suggest to solve the problem of  storage of floating point values in BRAM ipcore?Can i use any other ipcore for storing the floating point values?
Navya
You can't put real values directly this way because it's arbitrary. You need to actually specify the bit vector of the value you want to be stored in the BRAM in a way that makes sense for how the rest of the logic is going to interpret it.
For example, 2.5 can be represented as a fixed-point or floating-point value. What does your logic actually expect? Based on that, you would do the quantization of 2.5 to a fixed point value or convert it to single/double precision float format and enter the 32/64-bit value.
These might help:
https://www.h-schmidt.net/FloatConverter/IEEE754.html
https://www.rapidtables.com/convert/number/decimal-to-binary.html
www.xilinx.com
I want these stored real values to be given as input to the transform Ipcore block to perform the transformation. Do you mean bit wise equivalent of each digit by the term "bit vector value"? If so it will be difficult for long length of data. Could you please clarify my doubt once more?
Is there any other work around for the same?
Is it possible to store real values in FIFO ipcore block using COE file?
the coe format goes back a long time,,
as such, it does not understand floating point numbers which are relatively new to fpga's.
as for initialising values in a fifo at start up,
there are multiple ways that a fifo can be made in an fpga,
   from the flip flop based, through to srl, bram and built in fifo's
each have different characteristics,
the built in fifo's of some devices can't be initialised with data,
    some fifos can be cleared at reset, but
@navyamohan
I do this as follows:
   amp_ramb36_inst: RAMB36E1
   generic map
      RDADDR_COLLISION_HWCONFIG   => "DELAYED_WRITE",
      DOA_REG                     =>  0,
      DOB_REG                     =>  1,
      INIT_08(224 to 255)         => X"3A34F1E5", -- the average of the calibrated signals is 0.00069025  which is close to the theoretical value of 10^(( 0 - 63)/20) = 0.00070794578438413800
      INIT_08(192 to 223)         => X"3A4F8F75", -- the average of the calibrated signals is 0.00079178  which is close to the theoretical value of 10^(( 1 - 63)/20) = 0.00079432823472428100
      INIT_0F( 32 to  63)         => X"3F733024", -- the average of the calibrated signals is 0.949953333 which is close to the theoretical value of 10^((62 - 63)/20) = 0.89125093813374500000
      INIT_0F(  0 to  31)         => X"3F800000", -- the average of the calibrated signals is  1.0        which is close to the theoretical value of 10^((63 - 63)/20) = 1.00000000000000000000
      EN_ECC_READ                 => FALSE,
      EN_ECC_WRITE                => FALSE,
      INIT_A                      => X"000000000",
      INIT_B                      => X"000000000",
      INIT_FILE                   => "NONE",
      RAM_MODE                    => "TDP",
      RAM_EXTENSION_A             => "NONE",
      RAM_EXTENSION_B             => "NONE",
      READ_WIDTH_A                => 36,
      WRITE_WIDTH_A               => 36,
      READ_WIDTH_B                => 36,
      WRITE_WIDTH_B               => 36,
      RSTREG_PRIORITY_A           => "RSTREG",
      RSTREG_PRIORITY_B           => "RSTREG",
      SRVAL_A                     => X"000000000",
      SRVAL_B                     => X"03F800000",    -- Correction amplitude := 1.0 (ieee754 single precision) if no correction is required
      SIM_COLLISION_CHECK         => "NONE",
      SIM_DEVICE                  => "7SERIES",
      WRITE_MODE_A                => "WRITE_FIRST",
      WRITE_MODE_B                => "WRITE_FIRST"
   port map
      CLKARDCLK                   => i_cpu_clk,
      REGCEAREGCE                 => HIGH,
      RSTRAMARSTRAM               => LOW,
      RSTREGARSTREG               => LOW,
      ENARDEN                     => HIGH,
      WEA( 0)                     => i_ampl_usr_bram_wr,
      WEA( 1)                     => i_ampl_usr_bram_wr,
      WEA( 2)                     => i_ampl_usr_bram_wr,
      WEA( 3)                     => i_ampl_usr_bram_wr,
      ADDRARDADDR( 4 downto 0)    => LOW8( 4 downto  0),
      ADDRARDADDR(14 downto 5)    => i_ampl_usr_bram_addr(11 downto  2),
      ADDRARDADDR(15)             => LOW,
      DIPADIP                     => LOW4,
      DIADI                       => i_ampl_usr_bram_data,
      DOPADOP                     => open,
      DOADO                       => o_ampl_bram_usr_data,
      CASCADEINA                  => LOW,
      CASCADEOUTA                 => open,
      CLKBWRCLK                   => i_adc_clk,
      REGCEB                      => HIGH,
      RSTRAMB                     => LOW,
      RSTREGB                     => LOW,
      ENBWREN                     => HIGH,
      WEBWE( 0)                   => LOW,
      WEBWE( 1)                   => LOW,
      WEBWE( 2)                   => LOW,
      WEBWE( 3)                   => LOW,
      WEBWE( 4)                   => LOW,
      WEBWE( 5)                   => LOW,
      WEBWE( 6)                   => LOW,
      WEBWE( 7)                   => LOW,
      ADDRBWRADDR( 4 downto  0)   => LOW8( 4 downto  0),
      ADDRBWRADDR(10 downto  5)   => att_addr,
      ADDRBWRADDR(11)             => corr_ena_b,
      ADDRBWRADDR(15 downto 12)   => LOW4,
      DIPBDIP                     => LOW4,
      DIBDI                       => LOW32,
      DOPBDOP                     => open,
      DOBDO                       => amp_corr,
      CASCADEINB                  => LOW,
      CASCADEOUTB                 => open,
      INJECTSBITERR               => LOW,
      INJECTDBITERR               => LOW,
      SBITERR                     => open,
      DBITERR                     => open,
      ECCPARITY                   => open,
      RDADDRECC                   => open
Is this what you wanted?
Cheers
Goran
